Itemised billing
- Home Phone
- Re: Itemised billing
Itemised billing
27-09-2010 9:42 AM
Dear All,
How long after moving your phone to Plusnet should it take for itemised phone calls to appear in the calling/billing logs?
We moved over on the 8th September and calls started appearing straight after the move after about 48 houra. I've helped an friend of mine move over recently (15th September) and there are still no calls being logged in his account space.
Cheers,
David
Cheers,
David
Message 1 of 7
(18,335 Views)
6 REPLIES 6
27-09-2010 11:31 AM
I had a similar experience after moving my phone over in August. I can't remember how long it took for them to appear, but at least a couple of weeks.
They were all there in the end though!
Message 2 of 7
(786 Views)
27-09-2010 4:16 PM
Message 3 of 7
(786 Views)
28-09-2010 9:25 AM
There does seem to be a problem, my last call showing is 22 Sept and I'm sure that there have been some calls made since then.
Message 4 of 7
(786 Views)
28-09-2010 3:20 PM
Hi all,
David, re your account the itemised bill is showing, however no chargeable calls appear to have been made. which is why none are displayed. Please check again and let me know if that continues to be a problem for you.
reserved,
can you bear with me as I'd like to check our call processing records and check that against the data showing on your account, this can take a while but I will keep you posted.
reserved,
Message 5 of 7
(786 Views)
28-09-2010 3:58 PM
Quote from: _Adam_Walker_ can you bear with me as I'd like to check our call processing records and check that against the data showing on your account, this can take a while but I will keep you posted.
Thanks Adam
Message 6 of 7
(787 Views)
29-09-2010 9:10 AM
Now updated from 21 - 27 September
Message 7 of 7
(787 Views)
