Itemised Phone Bill Checker
- Home Phone
- Itemised Phone Bill Checker
23-05-2010 11:09 AM
Is there such a thing?
I've noticed that quite a few European phone companies provide the same to make splitting a bill between house-mates a little easier.....
Message 1 of 8
(2,124 Views)
7 REPLIES 7
Re: Itemised Phone Bill Checker
23-05-2010 3:55 PM
There is a completely itemised bill and you can also download a copy in csv format so you can analyse it in Excel or Open Office Calc
Message 2 of 8
(644 Views)
23-05-2010 4:00 PM
that is available on BT as well as on Plusnet home phone
and welcome to the Forum
Message 3 of 8
(644 Views)
23-05-2010 4:39 PM
Thanks for the answers and the welcome!
There are a few things around for this sort of thing, I'm struggling to find a decent excel template. But I guess I'll have to make one!
Message 4 of 8
(644 Views)
23-05-2010 4:55 PM
just open the CSV file in excell and all the info will be in headed columns, you can then sort the info (Data sort) on the number
Message 5 of 8
(644 Views)
23-05-2010 8:13 PM
Yea, I know I can do that.
What I was after is to have for example column 'A' to have the numbers called and column 'B' to have the numbers from my phone. Then for excel to highlight in column 'A' what is in column 'B' so I can see what I owe.
Then I could do it for the other 6 people in the house, just to make it a little quicker now and in the future. - It's been a few months since we went through it last time you see.
I'm working on it now...
Message 6 of 8
(644 Views)
23-05-2010 9:58 PM
You could use the vlookup command or even better try using pivot tables
Message 7 of 8
(644 Views)
23-05-2010 10:50 PM
I would create a sheet with a list of contact numbers from my phone and use vlookup as Jim says.
Message 8 of 8
(644 Views)
- Home Phone
