Is there a list of compatible phones for caller display?
nightsurfer
I have signed up for the new caller display option,  but the number is not displayed.
My phones;  Panasonic KX-TG1401 series, displayed the caller ID when I was with TalkTalk,  so I was hoping they would work with PlusNet,
Is there a list of phones which are known to work (or not work)?
32 REPLIES 32
Gel
Aspiring Champion
Fixes: 29
Re: Is there a list of compatible phones for caller display?
CLID
You have to select this £option£ with PN; go into MY ACCOUNT section of PN portal and select this add on.
nightsurfer
Hi, thanks for your reply.
I'm not sure what "£option£" in your reply refers to,  but when I check my call features in the Home Phone Control Panel it states that Caller Display,  Voicemail and Call Protect are all active.
However,  when I dial #234# on the phone it states caller ID will not be displayed.
Fixes: 1,600
Hi there.
I'm doing the good old remove and re-add trick which should fix this.
I'll let you know once it's re-added, should be within a few hours.
nightsurfer
Many thanks,
I will check this evening and report the result.
nightsurfer
Hi Gandalf,
I tried the phone at 6:25pm and no caller ID was displayed.
#234# reported that "caller IDs will not be displayed"
I will try again tomorrow.
Fixes: 1,600
Thanks for checking.
I've reported a fault to our suppliers for further investigation.
I'll update you when we know more.
198kHz
Fixes: 41
Gandalf is on the case, but I'll just add that there shouldn't be any compatibility issues in changing from TT to PN.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Aspiring Hero
Fixes: 73
Is the facility switched on?
If you've ordered Caller Display check it's switched on by entering the code * # 234 #.
If it's active you'll get the message Caller identity will be displayed. If the facility isn't active then activate it using the code * 234 #.
#234# turned off my cli.
Dan
RichardB
Seasoned Champion
Fixes: 39
As Dan states,
#234# turns caller id off.
Try *234# to turn it back on.
*#234# reports the on/off state of caller id.
nightsurfer
Ahh,  thank you.  I tried to find a list of codes,  but was unable to.  I will note these for later.
*#234# states that caller ID will be displayed,  Unfortunately it is not.
Perhaps the PlusNet system is different to the TalkTalk one and it just won't work for my phone.
Fixes: 160
There have been instances where the service is fully operational but a fault on a line card in the exchange inhibits correct functionality.
198kHz
Fixes: 41
If Caller Display works on your phone(s) with one ISP it will work with another.
Either it's not been provisioned correctly, or it's an exchange fault - very likely as described by @Townman.
Fixes: 1,600
In my experience the most common cause of a caller display fault are the tie pairs at the exchange. Last one I had there were LLU ADSL ties still connected to the line when the circuit was FTTC, which stopped caller display from working.
I'll update when we know more.
198kHz
Fixes: 41
Ah, thanks @Gandalf - I'd almost forgotten those bloomin' ubiquitous tie pairs.
