Is there a list of compatible phones for caller display?
FIXED- Subscribe to RSS Feed
- Home Phone
- Is there a list of compatible phones for caller di...
22-07-2018 7:44 AM
I have signed up for the new caller display option, but the number is not displayed.
My phones; Panasonic KX-TG1401 series, displayed the caller ID when I was with TalkTalk, so I was hoping they would work with PlusNet,
Is there a list of phones which are known to work (or not work)?
Fixed! Go to the fix.
Re: Is there a list of compatible phones for caller display?
22-07-2018 8:09 AM
CLID
You have to select this £option£ with PN; go into MY ACCOUNT section of PN portal and select this add on.
22-07-2018 8:19 AM
Hi, thanks for your reply.
I'm not sure what "£option£" in your reply refers to, but when I check my call features in the Home Phone Control Panel it states that Caller Display, Voicemail and Call Protect are all active.
However, when I dial #234# on the phone it states caller ID will not be displayed.
22-07-2018 12:30 PM
22-07-2018 3:48 PM
Many thanks,
I will check this evening and report the result.
22-07-2018 6:29 PM - edited 22-07-2018 6:31 PM
Hi Gandalf,
I tried the phone at 6:25pm and no caller ID was displayed.
#234# reported that "caller IDs will not be displayed"
I will try again tomorrow.
22-07-2018 7:04 PM
22-07-2018 8:40 PM
Gandalf is on the case, but I'll just add that there shouldn't be any compatibility issues in changing from TT to PN.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
23-07-2018 12:25 PM
Is the facility switched on?
If you've ordered Caller Display check it's switched on by entering the code * # 234 #.
If it's active you'll get the message Caller identity will be displayed. If the facility isn't active then activate it using the code * 234 #.
#234# turned off my cli.
Dan
23-07-2018 3:58 PM
#234# turns caller id off.
Try *234# to turn it back on.
*#234# reports the on/off state of caller id.
23-07-2018 6:04 PM
Ahh, thank you. I tried to find a list of codes, but was unable to. I will note these for later.
*#234# states that caller ID will be displayed, Unfortunately it is not.
Perhaps the PlusNet system is different to the TalkTalk one and it just won't work for my phone.
23-07-2018 9:27 PM
23-07-2018 10:19 PM
If Caller Display works on your phone(s) with one ISP it will work with another.
Either it's not been provisioned correctly, or it's an exchange fault - very likely as described by @Townman.
24-07-2018 8:27 AM - edited 24-07-2018 8:27 AM
In my experience the most common cause of a caller display fault are the tie pairs at the exchange. Last one I had there were LLU ADSL ties still connected to the line when the circuit was FTTC, which stopped caller display from working.
I'll update when we know more.
24-07-2018 11:33 AM
Ah, thanks @Gandalf - I'd almost forgotten those bloomin' ubiquitous tie pairs.
- Home Phone
