Is it okay to unplug my phone?
vikixc
I have had it 2 days and the cold calling has started -.- So is it okay to unplug it?
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: Is it okay to unplug my phone?
yes
vikixc
Excellent. I don't use it for anything anyway
daveplus
Fixes: 10
In case you ever need your landline phone, you could register with:
http://www.tpsonline.org.uk/tps/index.html
and also go ex-directory.
Oldjim
Resting Legend
Fixes: 63
and that has absolutely no effect (tps that is)
jelv
Fixes: 10
Keep hold of the handset - if you ever have problems with the broadband you may need to plug it in to check if the phone is working OK.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
vikixc
I triedto register with tps but it says my number is already registered  Shocked
I will leave it unplugged Wink
daveplus
Fixes: 10
Quote from: Oldjim
Well, it cut my unwanted calls substantially.
Oldjim
Resting Legend
Fixes: 63
I still get loads and I have had it for ages
Used to be - free insulation
Then PPP claims
and of course all the ones from Microsoft and International Unavailable
oldbaldeagle
Its also worth opting out of the 'Open' electoral register - https://www.gov.uk/electoral-register/opt-out-of-the-open-register
Legend
Fixes: 254
I used to get shed-loads of unwanted calls, but after ignoring any call where I didn't recognise the number (or it was unavailable/witheld), the incidence has dropped to 3 or 4 a week. Don't know if that's the reason, but I am happy.  Smiley
As a side-note, my 2 mobile numbers have had about half-a-dozen spam calls/texts between them, and I've had my Vodafone number for longer than I care to remember.
