Is 18185 service available with Plusnet Home Phone?
- Home Phone
- Re: Is 18185 service available with Plusnet Home P...
14-05-2014 11:01 PM
I am considering moving my phone to plusnet, I have found this Q and A in the home-phone-faq:
Can I use an indirect access provider to make calls?
Yes, although you should be aware that we can't offer support if there are problems with the service you're using.
but, specifically, will the 18185 override (which I currently use out of my BT line) work out of plusnet home phone?
Message 1 of 4
(1,139 Views)
3 REPLIES 3
Re: Is 18185 service available with Plusnet Home Phone?
14-05-2014 11:03 PM
Have a read through this thread: http://community.plus.net/forum/index.php/topic,126953.0.html
Call me 'w23'
Message 2 of 4
(502 Views)
15-05-2014 7:39 AM
"specifically, will the 18185 override (which I currently use out of my BT line) work out of plusnet home phone?"
Yes, been using it for ages and saved a fortune on call costs.
Message 3 of 4
(502 Views)
20-05-2014 9:58 AM
@w23 thank you for the link to that thread with an informative discussion (particularly on the second page) about carrier-preselect services.
@newagetraveller thank you for confirming it works for you!
Cheers.
Cheers.
Message 4 of 4
(502 Views)
- Home Phone
