Irregular Call Data Updates again
- Home Phone
- Irregular Call Data Updates again
Re: Irregular Call Data Updates again
21-04-2009 10:18 AM
Quote from: bobboulby I'm up to date to yesterday morning now.
Bob
I'm not - obviously Greenbee don't pay their bill as fast as Plusnet!
21-04-2009 10:27 AM
We had a problem with one of the servers which controls call processing on Friday. This meant we had to failover to a secondary server, and caused a build-up of calls to be processed. We have about 80k calls to process now, but most people should have up to date data. We expect to be fully caught up by about 3pm.
21-04-2009 12:13 PM
21-04-2009 12:31 PM
21-04-2009 12:40 PM
Quote from: Be3G I've not seen this described elsewhere in the thread, but I assume it's related: all calls from the 10th onwards (not that there are many) are duplicated - one confirmed, one unconfirmed.
See my reply to another thread on the same subject here.
It's to do with the order in which the scripts are processed. If your account was like mine the calls that were showing were already confirmed.
The unconfirmed call data has been applied after the confirmed data and thus has not been removed since the commands to remove the unconfirmed calls are likely part of the script which applies the confirmed data.
Only confirmed calls will land up on your itemised bill's call logs.
04-05-2009 6:29 PM
04-05-2009 8:39 PM
It shouldn't have anything to do with the holiday weekend, it's an automated system so it should continue running. I'll pick this up in the morning and see what I can find out.
04-05-2009 9:01 PM
04-05-2009 9:48 PM
05-05-2009 12:02 AM
Chris, this does seem to happen more frequently (but not always) at w/e's especially a holiday w/e. Obviously I don't know if it is a problem with the data coming from BT or a problem at PN.
14-05-2009 4:54 PM
18-05-2009 8:04 PM
18-05-2009 10:06 PM
19-05-2009 9:43 AM
As this is supposedly an automated process at PN, then presumeably there's a problem with data from BT?
But then again for calls to show as unconfirmed after they are confirmed, is that a processing issue at PN?
How is Call Data supplied by BT (obviously in a database - that detail is not especially of interest) ?
i) Does Unconfirmed call data get supplied separately from Confirmed or is this simply a processing thing?
ii) Does data get supplied in order of Exchange ID or STD code and in what order is it processed by PN?
iii) Does data from Satellite exchanges get delayed compared to main exchanges?
iv) Any other pertinent points?
19-05-2009 9:44 AM
They should catch up by the end of the day.
Chris - Unconfirmed calls are run in a separate report to how the calls are confirmed. I've no idea in what order we're actually supplied the data.
- Home Phone
