International access codes.
tayzi
While I am happy with Plusnet 77p per minute to Tunisia is a bit much. How much does plusnet charge for dialling a 09 international access code? All other providers are reasonable what about plusnet........?
8 REPLIES 8
adamwalker
Fixes: 221
Re: International access codes.
09 or premium rate numbers can be anything up to £1.50 per minute but this depends on the actual number being dialled.
 Adam Walker
tayzi
So how do I check how much this access code is with Plusnet, I cannot find anything on website.
adamwalker
Fixes: 221
I can check for you. Could you tell me the area code in full please? i.e is it 0906?
 Adam Walker
kraheem
hi
dose plusenet have any discount to (iraq , germany, norway) and what number i should use to get cheaper call?
thanks
prichardson
Checking the costs for any number is an art. Lets break it down for you.
First open one of the following links, depending on the number prefix you are dialing.
With these pages, you need to locate the best matching number from the list, that matches the most digits. e.g, if you have a number starting 08447173, use the entry "0855 717" and not "0844 71".
This will supply you wish a charge code. In the example above, you should obtain the code "g11", not "g19".
An 09xx example is a number starting 09021894, this matches the entry "0902 189", which is "ff11".
You can then look within our own tariff guide.
Locate the require code with a search, and you get the ppm rate.
g11 = 4ppm at all times
ff11 = 60.1ppm at all times
kraheem
thanks for your replay
could you please tell me wich number is good to use for ( germany and norway)
thanks
tayzi
The number starts 0911998.......
I think I have found its 18p per minute can u confirm
Thankyou
prichardson
That's correct. Code p32, which is £0.18ppm at all times.
