International Calls
- Home Phone
- International Calls
International Calls
20-11-2012 2:05 PM
Why is there no call feature that allows the rejection of International calls, I have no reason to receive calls from abroad (they are always unwanted sales/scams) so why can't there be an option to reject these similar to anonymous calls. Your system knows it's an international call because my caller display says so, therefore it must be technically possible.
Message 1 of 8
(3,924 Views)
7 REPLIES 7
Re: International Calls
20-11-2012 2:15 PM
Welcome to the forum fragile
Many of us would like that feature
Message 2 of 8
(565 Views)
20-11-2012 5:56 PM
Hi fragile - we buy our lines from BT Openreach and are restricted to the call features offered by them. Unfortunately no such feature exists so we can't offer it to our customers.
Message 3 of 8
(565 Views)
20-11-2012 8:39 PM
Anybody out there with a phone which achieves the same functionality, I can block numbers with my current phone but if there is no number then it's not possible.
Message 4 of 8
(565 Views)
20-11-2012 8:59 PM
That's the problem....no number.
However my phone can tell the difference between 'number withheld' and 'international' which still doesn't help
Message 5 of 8
(565 Views)
21-11-2012 10:10 AM
My phone has 'Withheld', 'Unavailable' and 'International'. Now it should be easy for a phone manufacturer to give you the option to put these on the bar list but I've not found one which does. I presume there is some reason why they don't but I don't know what it is. Paying £4/month to block anonymous seems a waste as it doesn't fully achieve the result I want as a large proportion are now Int calls.
Message 6 of 8
(565 Views)
21-11-2012 10:46 AM
Yeah...one of these would pay for itself inside a year.
Message 7 of 8
(565 Views)
21-11-2012 4:44 PM
Quote from: fragile Now it should be easy for a phone manufacturer to give you the option to put these on the bar list but I've not found one which does.
The best I can do with my phone is to set it not to ring when an anonymous call comes through. That, or I can choose to divert the call to answer machine (in which instance I would have to do that manually when the call is coming through), which I can set to announce such calls are not accepted and then it would disconnect the call. Gigaset SL910, if you're interested.
Message 8 of 8
(565 Views)
