Intermittant phone fault and no one has a clue
- Home Phone
- Intermittant phone fault and no one has a clue
21-06-2013 10:15 AM
I have been with Plusnet for over 8 years, and every time I report a fault, all they want to do is send out an BT engineer. I HAVE HAD SIX BT ENGINEERS TO THIS PROPERTY already, and none of them have been able to find a fault. The last engineer even told me that if the fault continues there is no point sending another engineer out to the property, since he has done everything he can to ensure there is no fault in the property. I have had both broadband and phone engineers around.
So why when I call customer service and reopen the fault do they insist on sending another engineer around, and then tell me I will have to pay if the fault is in my house, even though the last engineer said there is nothing wrong in the property.
I have had a new NTE installed, the upstairs sockets (which were installed by the builders) disconnected, so I have had no phone/net access upstairs (3 desktop computers with no wireless), tried 3 different phones, 3 routers, and filters. Incidentally, my father lives on the next street is with Plusnet and never has any issues (and I have even borrowed his equipment to test it). And I have tried things in the the test socket (now I actually have one and they got rid of that pathetic External NTE).
I just feel I am wasting my time with this, because no one is looking at the history of my problem even when they are given the ticket numbers, and because it is not a typical fault, I get given the third degree like I don't know what I'm talking about - I've got an MSc in IT, so I'm not computer illiterate.
Has anyone on here got any idea?
Re: Intermittant phone fault and no one has a clue
21-06-2013 11:02 AM
21-06-2013 11:14 AM
Have you set up RouterStats to monitor your line and see if there is any pattern to when the problem happens?
3Mb FTTC
21-06-2013 1:04 PM
Sorry to hear about the issue with the line I'l do my best to help out and see what advice I can offer.
Quote I have been with Plusnet for over 8 years, and every time I report a fault, all they want to do is send out an BT engineer. I HAVE HAD SIX BT ENGINEERS TO THIS PROPERTY already
Its the same for most reported to us, my advice would be to persist with this one and stick with it, I'll even volunteer to keep an eye on how were getting on with the fault ourselves to make sure we're doing absolutely all we can, this may take a little time, a few more engineer visits and some deal of patience is all that's needed.
As godsell4 mentions I have a feeling too that environmental factors could be at play here. So I'd also advise keeping a note book handy to jot down what the weather conditions are like against where you are when the issue happens, it might sound a bit strange but it does help.
I can see that a new line fault is open and that we're expecting a response by the 25th so I've set myself a reminder to check back as to how things are with your service and see if you've got back to us in the meantime.
All the best,
Adam
21-06-2013 1:20 PM
That sounds like an HR ( high resistance ) fault...
Quote The only way to get it back up is to receive an incoming call (usually from my mobile).
21-06-2013 2:01 PM
Not only should you note the weather at the time of a fault, but also record what it was like for the preceding couple of days.
22-06-2013 1:27 PM
I don't think it is weather related, the weather has been fine here all week, and the last time this problem occurred was yesterday.
Incidentally, other line problems include incoming calls causing the broadband to disconnect, and the router synching at ridiculously low speeds, particularly the upstream, sometimes as low as 39kbps, instead off 800kbps (when it is at this low speed, an incoming call causes a disconnection and it synchs back at the normal speed) . Again these are rare occurrences, once or twice per month, but no set interval.
Here are some recent dates and times when the phone line was dead, there may be more but these are the ones I noticed:
28/03/13 11:30am
15/04/13 11:54am
30/04/13 11:58am
Was on holiday for 3 weeks in May so unable to monitor
21/06/13 08:54am
BT never find any faults, and as stated I have changed out all my equipment and the problem still occurs.
22-06-2013 6:36 PM
It doesn't sound like an exchange fault as the fault seems a little too intermittent and doesn't show any real pattern.
25-06-2013 12:35 AM
25-06-2013 1:43 AM
25-06-2013 3:50 PM
I've just had a look at your fault and I can see that engineers believe they've fixed a fault discovered on the network today. We'll obviously not be able to tell for a few days if this has helped so with that in mind I'd recommend that we take a look at your connection logs together on Friday.
26-06-2013 10:56 AM
Can you tell me what the fault was that they found?
Also due to the frequency of the fault in the past, I think it will need a month without the fault recurring to be certain it has been fixed. If it has been fixed then that is great news.
26-06-2013 3:59 PM
We're not party to the explicit details I'm afraid but a fault on the "local network" has been fixed that usually means a section of cable or cable joints have been replaced.
Quote Also due to the frequency of the fault in the past, I think it will need a month without the fault recurring to be certain it has been fixed. If it has been fixed then that is great news.
Do bear in mind that it's quite normal for a connection to drop out every few days or for some even once or twice a day, that in itself shouldn't have an detrimental effects but, just don't want you to expect a month long connection before being satisfied as to be realistic that might not happen
Here's how it's looking at the moment:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13722587589857.png"/>
27-06-2013 12:40 PM
I actually meant a month long without the phone line going dead which was the original problem I reported. Hopefully though this will fix it and improve the general stability of the broadband.
23-07-2013 5:29 AM
Is there not anyone available who can actually look into this, because every time I report this issue I get the same response: have you done this, have you done that. Yes I have.
The last BT engineer confirmed there were no faults in the house or with my equipment, but you want to send another one round!!! It seems like every time this fault occurs I am back to square one reporting it.
I did manage to call Plusnet whilst the line was dead from a mobile and they found this fault:
Fault Type:NDT
Test Results:Fail - Fault located at exchange (Openreach side of MDF)
Description: FAULT - Dis One Leg in Exchange
However, as soon as an incoming call is received the fault is cleared. Obviously there is something wrong somewhere.
- Home Phone
