Increase in Nuisance Calls
- Home Phone
- Increase in Nuisance Calls
07-10-2014 10:29 AM
Over the past few months we have been receiving an increase in the number of nuisance calls that we receive.
These aren't your normal sales/marketing calls you get from a human but are pre-recorded messages about government grants for gas boilers, solar panels etc also PPI refunds.
The calls show on caller display as either 'Unavailable' or 'International' so there is no number to report or block.
We are already registered with the TPS but that clearly doesn't stop this type of call.
Is there anyway to stop these calls? (One call did say to press 9 to be removed but I'm not convinced that would be a good idea. Might lead to even more calls)
Can Plusnet do anything?
TIA
Re: Increase in Nuisance Calls
07-10-2014 10:42 AM
If anyone needs to contact me and withholds their number they'll have to either unblock their number and try again or find another way.
07-10-2014 11:33 AM
@Strat: I assume the anonymous call setting requires Caller Display? Is that correct?
07-10-2014 11:37 AM
07-10-2014 12:11 PM
I have a BT 8500 with advanced call blocker and it can block all these calls, International, Withheld, Out of Area and any other calls you want to block as well. It costs approx 50£ but for me it is well worth the money. The only calls that come through are numbers in the contacts in the phone, any other callers you can either answer, block or hang up after they have given their name before you allow the call to come through.
Ron
07-10-2014 1:38 PM
07-10-2014 2:06 PM
Quote from: sjptd @Strat: I assume the anonymous call setting requires Caller Display? Is that correct?
It is correct.
07-10-2014 2:11 PM
Quote from: daveplus Going ex-directory dramatically reduced the number of such calls I receive...
I've just recently applied to go ex-directory (I thought I was) having recently received a phone book with my details in.
Personally I don't expect it to have any effect on cold call numbers as my details will be on numerous databases worldwide and easily accessible by the phone spammers.
I'm registered on the various Preference Service databases but they have no effect outside the UK......or with some companies, within the UK
07-10-2014 2:25 PM
As Salmo rightfully points out; occasionally I'll get a call from someone really important who withholds their number. Otherwise I'd use "Anonymous Call Reject" as a feature.
From a Plusnet perspective, this is the best feature we can really offer to counteract the calls. Unless, of course, you want to go nuclear and renumber your line.
08-10-2014 5:08 PM
Not a lot can be done then unless I spend money on a special phone to block these calls.
Quote from: MattyC The problem for me was always that I couldn't differentiate the anonymous calls.
As you said "Anonymous Call Reject" would also block legitimate and it costs £4 per month from Plusnet!!!
I really don't want to have to change my number either.
Edit
One other thing, these calls have increased since I moved to Plusnet from BT, how much of a coincidence this I don't know.
08-10-2014 5:36 PM
I'm sorry to hear of the calls.
We didn't really change too much as your line was just a direct transfer, were you previously ex-Directory?
Matty
09-10-2014 11:54 AM
dick:quote
09-10-2014 3:07 PM
09-10-2014 3:16 PM
NOT answering these calls does seem to have improved the situation and reduced the frequency -touch wood!
09-10-2014 4:22 PM
Unfortunately, as I am a 'nominated person' for dealing with my mums bills/care etc. since her stroke, I have to answer 'witheld' calls, but just say 'hello, who's calling?' If that gets no answer, or some muppet tries a sales pitch, they are then told they are calling a ficticous company. That seems to hve stopped around 95% of my unwanted calls.
