Incoming calls
- Home Phone
- Incoming calls
- « Previous
- 1
- 2
- Next »
Re: Incoming calls
10-12-2013 2:33 PM
Thanks for your time on the phone.
I spotted that you have anonymous caller reject turned on. Part of my thinking is that the hospital may be withholding their number, so I have removed this, which should take about 24 hours to complete.
Let us know if you still have problems.
Message 16 of 19
(252 Views)
Re: Incoming calls
10-12-2013 2:55 PM
@gleneagles
If you have a mobile could you ask them to try calling it so you can see if their number is displayed?
Message 17 of 19
(252 Views)
Re: Incoming calls
10-12-2013 3:11 PM
Order to remove ACR has now completed.
Message 18 of 19
(252 Views)
Re: Incoming calls
10-12-2013 5:34 PM
Quote from: gleneagles ...she phoned me back to say she was getting a call blocked message when trying to contact me BUT by phoning me on the BT Line she was able to get through to me.
Given James' findings, the call placed from the BT line being successful might suggest that the CLI is not withheld on the hospital's BT lines as I believe anonymous call reject is absolute. This does not though (until verified) mean that the problem with the main switchboard is definitely identified. My experience dialling anonymous caller reject frm a line which hides CLI is a recorded message stating that this line does not accept calls from withheld number lines. One wonders if ther switchboard incorrectly (or inadequately) reports he situation.
Seems that a little challenging question has progressed this OP's issue - is it possible that the OP on the other thread has the same issue, with the VoIP services misreporting the problem?
Cheers,
Kevin
Message 19 of 19
(252 Views)
- « Previous
- 1
- 2
- Next »
