Incoming calls fault - not ringing
- Home Phone
- Incoming calls fault - not ringing
03-09-2017 8:14 PM
We have a fault on our land line, all incoming calls are showing as missed calls and not ringing.
We've tried a different phone and also plugged it into the master socket and we still get the same fault.
Any suggestions?
Re: Incoming calls fault - not ringing
03-09-2017 9:24 PM
Time to report it as a fault, more details here.
03-09-2017 10:29 PM
Assuming you can make outgoing calls, then pound to a penny it's an exchange fault.
Shouldn't take long to fix.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
03-09-2017 10:33 PM
Any suggestions?
Just to make sure you tested the phone in the test socket of the NTE5? if you just plugged it into the front of the socket then any faulty extension wiring still connected could still cause the phone not to ring.
03-09-2017 10:39 PM
Good point 2u2me - I misread 'master socket' as 'test socket'.
04-09-2017 10:54 AM
Sorry to hear you're having problems with your phone service
I've created this ticket on your account with a few further checks you could try. If the problem remains please reply to the ticket and we'll arrange an engineer visit to further investigate.
Thanks,
Anoush
- Home Phone
