Incoming calls fault - not ringing
McLellans
We have a fault on our land line, all incoming calls are showing as missed calls and not ringing.
We've tried a different phone and also plugged it into the master socket and we still get the same fault.
Any suggestions?
5 REPLIES 5
Mustrum
Fixes: 77
Re: Incoming calls fault - not ringing
Time to report it as a fault, more details here.
198kHz
Fixes: 41
Assuming you can make outgoing calls, then pound to a penny it's an exchange fault.
Shouldn't take long to fix.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
2u2me
Any suggestions?
Just to make sure you tested the phone in the test socket of the NTE5? if you just plugged it into the front of the socket then any faulty extension wiring still connected could still cause the phone not to ring.
198kHz
Fixes: 41
Good point 2u2me - I misread 'master socket' as 'test socket'.
Fixes: 1,600
Sorry to hear you're having problems with your phone service
I've created this ticket on your account with a few further checks you could try. If the problem remains please reply to the ticket and we'll arrange an engineer visit to further investigate.
Thanks,
Anoush
