Incoming SMS messages delivered as voicetext?
- Home Phone
- Incoming SMS messages delivered as voicetext?
11-02-2012 12:43 AM
What do I need to do to keep them as text messages?
The instruction book for my phone (BT Relate 2100) says the SMS service is provided by BT, and that the first SMS message you send registers for the service.
I've done that, and received an SMS welcome message.
But subsequent incoming SMS are delivered as voicetext.
Any ideas?
Martin
Re: Incoming SMS messages delivered as voicetext?
13-02-2012 2:21 PM
13-02-2012 4:07 PM
13-02-2012 4:36 PM
14-02-2012 12:15 AM
14-02-2012 8:52 AM
Quote If you wish to adjust the settings for the SMS to Voice Service, please dial the following number.
08005875252
It will read out your telephone number and also advise of the current option selected.
The default option is the Watershed option.
The options are
1) Any time
2) Watershed ( 09:00pm to 09:00am )
3) Standard ( 11:00pm to 07:00am )
4) Late Night ( 12:00am to 06:00am )
5) Off
These changes normally take effect within 20 minutes.
As you can guess, using 5 to turn it off should switch it to SMS>SMS (providing your handset is compatible.
15-02-2012 8:24 PM
So I've set it to option 5 & we'll see what happens.
But we're pretty sure that that some of the voicetexts were received during the day.
In any case, I was doing some texts last evening & they were working fine.
(Well, almost fine, I got two which received only the last 12 or so characters of the message - I had to phone the person in the end, but I'm sure that's a different problem.)
Thanks for this.
Martin
16-02-2012 1:12 PM
17-02-2012 6:22 PM
Does one needs to sign up for SMS package to receive SMS on landline?
Chandu.
17-02-2012 7:33 PM
19-02-2012 1:57 PM
Which I have. So, I need to select the option 5 to receive the SMS as SMS.
Chandu.
20-02-2012 5:58 PM
Quote from: _Adam_Walker_ I've found some information that may help, it's our instructions for using the service:
08005875252
The options are
1) Any time
5) Off
I used to have SMS messages included with my BT package before but wasn't aware Plusnet offered SMS service - an agent response also said there was no SMS service ???.
Would any SMS messages be bundled in with Plusnet Home Phone and how much to send SMS messages?
21-02-2012 10:10 AM
Quote an agent response also said there was no SMS service
Sorry if that was the case.
Quote Would any SMS messages be bundled in with Plusnet Home Phone and how much to send SMS messages?
Good question, I'll endeavour to find out ASAP.
21-02-2012 1:02 PM
21-02-2012 4:21 PM
Is it possible to suggest this to the 'products' team especially given the imminent product refresh - I guess it would be fairly cheap and a nice addition?
Edit: Just checked and the Standard curfew is 11:00pm to 08:00am Changed voicetexts to off (5) which takes 20mins according to the announcement.
- Home Phone
