Inbound SMS not working
glloyd
Incoming SMS messages are being changed to text to voice messages. Outgoing SMS messages are fine. It used to work OK but sometime recently it's stopped working. Any ideas?
11 REPLIES 11
adamwalker
Fixes: 221
Re: Inbound SMS not working
It's not a feature we support either way I'm afraid but I am aware that there are some options you can dial to change the options as to how you receive SMS.
 Adam Walker
glloyd
That's a new one on me then it has worked until recently. Outgoing SMS work OK and when I re register it says I can send and receive SMS messages. Are you saying incoming SMS are not allowed with PlusNet home phone now?
henbane
That is an interesting post.  PlusNet being part of BT I would have thought SMS would have worked the same..  I am just about to move my home phone over to PlusNet  where I have my broadband.
glloyd
It did work and when you register it says you can send and receive SMS but it keeps converting to voice text which is damn annoying.
Petard
(Since it's free) I've just sent a text to our landline as a test, and it arrived just fine. Whatever your problem is, it's not PlusNet-wide.
Clarification on 12/11/25: the SMS arrived as text, not voice.
henbane
Oh good - I rarely use the SMS on my landline but its nice to know that if someone does send it a text it will deliver it with sms to voice - which is what I get from BT.  Never knew you could receive them to a phone on a landline, just used to caller display.  Smiley
NedLudd
Just tried it on mine. It went to voicemail!
Geoff,
York.
glloyd
I've tried from several mobile phones in case it's a carrier problem  but it still reverts to voice. Sometimes it says it's been delivered as voice mail when it hasn't done anything.
Quote from: Petard
Petard
A couple of thoughts (if you haven't had them already)....
Are your service centre numbers right? If you've re-registered OK, I imagine they are. http://tinyurl.com/cqsjzpt
Have you tried disabling voice texts (done by sending a text, apparently)? http://tinyurl.com/d6fjtml
Hope this helps.
NedLudd
Thanks for that Petard. All working now after sending 'register' to 00000 on the landline handset!  Grin
Geoff,
York.
glloyd
It looks like the inbound sms service is broken. When testing yesterday the home phone rang several times but only got the dialling tone then after about six attempts I got a voice message, no text.tried several times.
