In way over my head!
- Home Phone
- In way over my head!
08-07-2010 9:24 AM
I've recently moved into my own place, and want the interent. Now, I've ordered the internet as far as I know... lol
I've got this "Home Phone product: Talk Evenings & Weekends Phone number: <snip>Credit balance: 55.00" because I need a landline to get onto the internet yes? But I haven't got the little white socket thing that the phone plugs into? I'm not in the least bit bothered about having a home phone, I just want the internet!
Where does it all plug into etc? I'm still waiting for all the broadband bits to turn up.
Cheers
jim:green phone number removed but put in hidden boards if needed mod:end
Re: In way over my head!
08-07-2010 9:35 AM
I'm a bit bemused by that, as you have an active line which requires you to have a phone socket, so you must have one there somewhere.
Although you may not want to use the phone, you have to have an active line for us to supply broadband on. The talk evenings and weekend package is free, and comes with the most basic phone line rental @£11.25. You don't have to use the phone at all. In fact, you don't even need to have one plugged in!
But you'll have to have a good look round for that phone socket, it's got to be there somewhere!
Jojo
08-07-2010 9:50 AM
Quote But you'll have to have a good look round for that phone socket, it's got to be there somewhere!
Start with where the phone line comes into the property. You'll either have an overhead line from a pole usually attached to the wall just under the eaves, or if its underground there will be a small grey box ( about 6"x4" ) attached to the wall about a foot above ground. From either of these a cable will go into the house and tracing that should get you to the phone socket.
08-07-2010 11:06 AM
Quote from: Joanne I'm a bit bemused by that, as you have an active line which requires you to have a phone socket, so you must have one there somewhere.
Unless the wiring and phone pre-dates 19 November 1981. Before then one had to have ones phone hard-wired in by BT (or Post Office if going back even further).
12-07-2010 2:12 PM
P.S. in some new builds, the sockets have been fitted in the attic - make sure you check everywhere and if possible, follow the cable from outside the building to make sure it's not hidden somewhere.
12-07-2010 3:35 PM
Found it over the weekend thankfully! I think I said I didn't have a line going into the property when I ordered the service and I had to pay extra? Not 100% sure on that, but is it refundable?
Many thanks, Adam.
12-07-2010 3:44 PM
13-07-2010 10:14 AM
The hardware came through today... fingers crossed I can fathom it out and get the net up this evening!
13-07-2010 12:59 PM
