If i switch who maintains the physical line
- Home Phone
- If i switch who maintains the physical line
15-12-2007 12:19 PM
Re: If i switch who maintains the physical line
15-12-2007 12:36 PM
15-12-2007 12:57 PM
15-12-2007 1:08 PM
15-12-2007 1:20 PM
I want to switch but live in a rural location and suffer from occasional line damage from trees and lorries all of witch is fixed swiftly by BT for free.
i am just worried that i will be left in a no mans land if there is a fault with both BT and Plusnet passing the buck or just not interested
would be reassured to hear from a user with experience of the system working well.
15-12-2007 3:13 PM
I reported a line fault to PlusNet last Sunday lunchtime.
I got a phone call on Monday morning from PlusNet to arrange a visit by BT Openreach.
The BT Openreach engineer attended on Wednesday afternoon as arranged.
Regards .....
15-12-2007 4:09 PM
Quote So theoretically it should simply mean that you dial PN instead on 150
You actually have to dial the standard 0114 support number. 150 doesn't work on a PN line - you get a message telling you to dial Plusnet's support number which will come out of your inclusive calls - or it may be counted as a PN to PN call and be free anyway.
15-12-2007 4:13 PM
If you switch to us your line is still maintained by BT Openreach, as it is now.
You would report a fault to us, and we would then raise a fault to Openreach.
I have to say that our faults guys are very very good with Home Phone, and the system works well. It's often possible to get engineers out within 24 hours should this be required.
Our support line does not count as a free PlusNet to PlusNet call, but it is an 0114 number which means it's often free in mobile contracts.
15-12-2007 4:43 PM
We can divert your line to any number you determine should you have a fault on your line, although you would need to specifically request this as it requires a manual order to be placed.
15-12-2007 5:41 PM
That said, there are very few Home Phone faults so I don't think this would be an issue if there was a proven demand for it.
Feel free to raise a PUGIT, and we'll consider it if the demand is there.
18-12-2007 8:03 PM
So, what is the number I need if I ever have to report a fault?
If there was a fault in the line outside the house, but over my property - would I be charged for that? I'm sure BT only charge if it's in the property.
18-12-2007 9:29 PM
If the fault is anywhere up to the master socket in your house then you won't be charged (same as with BT). If the fault is in your own wiring or with your equipment then you probably would incur a charge (as with BT).
The line is still maintained by BT Openreach regardless if you pay PlusNet or BT Retail for your line rental.
18-12-2007 10:25 PM
Regards .....
19-12-2007 6:31 PM
27-12-2007 11:35 AM
Quote from: Mand Sorry, missed that question.
Very recently I had a line fault which rendered my line unusable and I had all my incoming calls diverted to my mobile number. BIG mistake - I was charged for all diverted calls at mobile rates. Fortunately, I only received one call but had I been made aware of this charge, I wouldn't have agreed to have my calls diverted. Good job I didn't receive any international calls!
Regards .....
- Home Phone
