I'm Hardly Making Any Calls
- Home Phone
- I'm Hardly Making Any Calls
12-06-2012 6:50 PM
Thanks...
Re: I'm Hardly Making Any Calls
12-06-2012 7:02 PM
Go here http://www.bt.com/pricing/current/Call_Charges_boo/1632_d0e5.htm#1632-d0e5 and look for the number - note that there are a number of 08444 options.
Once you have the pricing band you can go http://www.productsandservices.bt.com/consumer/consumerProducts/pdf/SpecialisedNos.pdf page 7
12-06-2012 7:06 PM
12-06-2012 11:37 PM
12-06-2012 11:44 PM
So who lived in Carlisle and was registered at a doctor's surgery in Margate, called to make an appointment to take advantage of the local rate charge of an 0845 number
13-06-2012 2:30 AM
13-06-2012 8:39 AM
There is nothing to stop the GPs Practices from leasing a block of local geographic incoming phone numbers (channels/lines) and assigning just one number from the range to be used across the range of channels/lines. If the first line is busy the caller is automatically rolled over to the next line until all of the lines in the block are in use. This is called Rollover or line hunting. Generally there is a small extra charge (to the GP) for the feature. The impact to the patients is they only get charged a local rate, for most fixed line/mobile call packages that is their calls are effectively free.
Edit: there's a similar situation with the 0844 numbers.
13-06-2012 11:42 AM
I thought the (previous) Government had said that GP practises should not use 0844 numbers charged at the higher rates (upto 10ppm) from a UK landline.
A small correction to Jim's post though, once you have looked up the Charge band at http://www.bt.com/pricing...o/1632_d0e5.htm#1632-d0e5 you should then get the price from http://www.plus.net/residential/tariffs/homephone.html about halfway down the page is the Specialised Number Tariff - look for the relevant Band code. It's likely to be one which is the same rate 24/7 and not as cheap as a local call
Next time you visit the Surgery, ask them what there standard landline number is (they are bound to have one because the 0844 number has to "translate" to it. Tell them you sometimes have to call from a mobile and 0844 costs are prohibitive, you want to be able to use your inclusive minutes
You could have a close look at their literature or website if they have one, the info may be there, or look to see if they give a number to call from abroad.
If you can't get the number complain to the NHS Trust (if it still exists!). Failing that, contact your MP.
13-06-2012 11:46 AM
Quote from: BryanP Why is a Doctors Phone an 0844 number, they are normally 0845 numbers which should charge local rate
Not true on two counts - most surgeries that are breaking the rules (it's a long story - see http://davidhicksonmedia.blogspot.co.uk/ if you're interested) use 0844, not 0845, and 0845 is not local rate and hasn't been for many years. It is, however, included in some bundles whereas 0844 is not.
13-06-2012 11:57 AM
13-06-2012 12:07 PM
13-06-2012 12:12 PM
http://en.wikipedia.org/wiki/Non-geographic_telephone_numbers_in_the_United_Kingdom
13-06-2012 12:18 PM
13-06-2012 12:42 PM
Anyway this 0845 stuff is a bit off-topic as the OP was asking about the costs related to his 08444 calls to his doctor's surgery.
13-06-2012 12:47 PM
- Home Phone
