How to turn OFF 1571
Lambchop
Hi all, how the hell do i opt out of 1571, as I'm plagued with spam calls leaving messages..
thanks  Tongue
10 REPLIES 10
picbits
Re: How to turn OFF 1571
You can turn it off by logging on to your account, choosing your phone service and disabling it in there Smiley
*edit - log in then click this link :
https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features
Lambchop
Thanks for that  Grin Cheesy will disable the caller Id or will that stay ?
picbits
Callerid is a different option so it should be fine.
Lambchop
Many many thanks Dom, youve made an old man very happy  Cheesy
lemming
I had the same question.  I'd anticipated that there would be a function enabling 1571 subscribers to toggle the service on or off, ad lib, from time to time.  The current Remove Call Feature sounds a bit more heavyweight, but maybe isn't.  Will there be any problems in repeated use of Remove or Add Feature for the 1571 service?
MattyC
Fixes: 46
There shouldn't be. Though if there is, we can just place an order at wholesale level to turn it off/on rather than automation.
lemming
Thanks.  I've just removed free voicemail via Members Centre.  It does seem to be a  more heavyweight procedure than  a user toggle switch -- the system response was that a voicemail removal update would take three working days.
PeterLoftus
Fixes: 5
@lemming toggling it as you suggest might cause PNs systems to throw a wabbler they are not that robust  Roll_eyes
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
lemming
In fact it was, and was shown as, disabled when I checked an hour ago.  I should really have checked yesterday, to see if it took effect more or less immediately.
catelliott
Adding and removing it at your leisure shouldn't be an issue, it can take up to three working days to add/ remove though, so it can't just be toggled on/off within a few seconds Smiley
