How to Enable SMS Receipt on my Plusnet Landline with a Compatible Handset
- Home Phone
- Re: How to Enable SMS Receipt on my Plusnet Landli...
09-11-2015 10:52 PM
I have just switched landline from BT to PlusNet.
I used to receive and send SMS texts via my compatible handset with BT.
How do I set up PlusNet to do the same?
Message 1 of 4
(2,546 Views)
3 REPLIES 3
Re: How to Enable SMS Receipt on my Plusnet Landline with a Compatible Handset
10-11-2015 9:48 AM
It should work just the same as with BT.
Caller Display is required (optional extra @£0.99/month on Plusnet Home Phone).
You may need to re-register to enable the service, see this BT guide: http://bt.custhelp.com/app/answers/detail/a_id/8510/~/all-about-bt-text
Call me 'w23'
Message 2 of 4
(1,306 Views)
14-11-2015 12:52 PM
Many thanks. Now set up.
Not as good as BT though as they gave you 200 free texts per month and then 10.5 p each thereafter. Plus net does not seem to have any free texts and they are charging 12 p per text for using the BT service!
Message 3 of 4
(1,306 Views)
16-11-2015 5:30 PM
Hi johnstripe
Unfortunately it is something that we do not provide any text packages with
Message 4 of 4
(1,306 Views)
- Home Phone
