How long for a call feature to start?
drt170
Hi
I added Call Protect yesterday in my account due to the high number of spam calls I'm getting, I've also got TPS.
Over 24 hours later and in my account it still says that Call Protect is awaiting activation.
Any idea how long this takes please?
Thank you
25 REPLIES 25
Fixes: 1,600
Re: How long for a call feature to start?
It's possible the call feature is stuck on your account as it shouldn't take longer than 24 hours. The service may actually be working though, have you tried dialling 1572?
Either way it looks like we'll need to get this manually sorted out for you and we'll get back to you when we're back in the office tomorrow. Smiley
drt170
Thanks for the reply.
No, not working, I just get the message "The service can not be connected"
I'll wait for further updates tomorrow.
Cheers
Duncan
Fixes: 1,600
Ah, no problem Duncan.
Fingers crossed there are no issues with us sorting this out for you, because in very few instances Call Protect isn't compatible with some exchange equipment so I'm wondering whether the order with our suppliers had been rejected due to this, which may explain why it's stuck.
We'll see what tomorrow brings Smiley
drt170
Great thanks Gandalf, will wait to hear from you.
Cheers
Duncan
drt170
Not heard anything back during the working day???  Still not working either?
Duncan
Fixes: 1,600
Hi Duncan, sorry for the delay.
It looks like this failed because we didn't update the telephone number on your account following renumbering your line. I've manually placed an order to activate Call Protect and it should start working within the hour.
I've also raised a task with the relevant team to fix the the stuck feature on your home phone control panel, which should be sorted within the next 24 to 48 hours. I've also updated your phone number so this sort of thing shouldn't happen again.
Can you let me know how it goes?
drt170
Many thank for that Gandalf. It does explain the email I have just had about my details being updated by Plusnet Support.
I will update you, probably tomorrow morning though.
Thanks again
Fixes: 1,600
No problem Duncan, the order has actually completed now so it should be working whenever you've got a chance to check. Appreciate it's a bit late at night though! Cheers -Anoush
drt170
Wooo Hooooo all working!!!!
Many thanks for your help, just going to have a read up now see how it all works
drt170
If it helps anyone else just found this:
Call Protect Menu
Dial 1572
Main Menu
  • Press 1 to add the last answered call to your diverted caller list.
  • Press 2 to remove the last entry from your diverted caller list.
  • Press 3 to listen to your 1572 messages.
  • Press 4 to change your personal options including –
    Plusnet's diverted list
    Your diverted list
    Diverted call groups
    VIP list
    DND settings
    Or hold to hear these menu options again
Fixes: 1,600
Excellent, I'm glad to hear that Duncan Cheesy Let me know if there's anything else you'd need help with
drt170
Ha ha, funny you should mention that.  I just added call barring, it was added within an hour, so that's a great improvement, I went by this guide that was included in the email, however, when I get to premium rate numbers, it fails, all others work fine though, any ideas please?
Duncan
*341# - This will bar almost all calls from your phone
*342# - Bar national and international calls and calls to mobiles
*343# - Bar international calls
*344# - Bar all operator calls
*345# - Bar any numbers with a * or # in them
*347# - Bar calls to premium rate numbers
Fixes: 1,600
Haha no problem, and that's odd. What happens when you try, do you hear a message?
drt170
*347# I get " the number you have dialled has not been recognised"
If I dial *#34# premium is not selected as barred
Weird?
