How do I view a break down of my current bill
gq4yjs
I have searched the Plusnet web site but cannot work out how to view my bill.I need to do this as my bill gets larger and larger yet I make very few phone calls.Thanks and regards to all Barrie.
1 REPLY 1
Oldjim
Fixes: 63
Re: How do I view a break down of my current bill
This may help
https://portal.plus.net/my.html?action=myconnection
Select Phone Calls from the left hand menu
Then Home phone - View
Then itemised bill which is the current bill and you can select the time period of the bill you wish to view
