How do I turn on call barring for all outgoing calls
- Home Phone
- How do I turn on call barring for all outgoing cal...
24-02-2016 11:22 PM
I've just signed up for Plusnet broadband, and I'd like to bar all outgoing calls (don't care about incoming) once the line goes live. How do I do it? According to the links below, it may not be very straightforward to set up, so I'd like to know what the feature is called exactly before calling customer service.
http://community.plus.net/forum/index.php/topic,122209.msg1059443.html#msg1059443
http://community.plus.net/forum/index.php/topic,115314.msg994023.html#msg994023
http://community.plus.net/forum/index.php/topic,110638.msg947771.html#msg947771
http://community.plus.net/forum/index.php/topic,97116.msg819511.html#msg819511
Re: How do I turn on call barring for all outgoing calls
24-02-2016 11:39 PM
25-02-2016 1:19 PM
Can you confirm that the information in the links is no longer valid?
Is there any way to block outgoing calls, like applying a usage cap? Can RTCC be put on my line when I have no arrears?
I may need to switch to a provider that offers call barring, if I cancel the order, is there a charge and will I get back the upfront line rental?
25-02-2016 1:51 PM
25-02-2016 2:51 PM
Thanks for your reply.
Your RTCC description sounds very similar to what's mentioned in the links. Would you be able to apply RTCC to my line when it goes live or do I need to call customer support? Is it possible to check if RTCC is enabled in Member Centre?
25-02-2016 3:21 PM
25-02-2016 4:04 PM
If I cancel the order within 14 days cooling off period, I won't be charged and will get back what I've paid?
25-02-2016 4:32 PM
If you are within your cooling off period, then you would be able to cancel for a full refund.
25-02-2016 6:01 PM
25-02-2016 10:23 PM
25-02-2016 10:41 PM
Would you be able to set my credit limit to £0 when it goes live or do I need to phone customer support?
25-02-2016 10:46 PM
26-02-2016 9:54 AM
You could always try another approach, i.e. use a phone/system that allows outgoing call blocking.
e.g. the Gigaset N300 (VoIP) base station which I use has the facility to not use the fixed line for outgoing calls. A simple belt and braces approach (if not using VoIP) would also be to create a number of rules (10) in the dial plan to block all numbers beginning with 0-9.
Obviously that wouldn't stop someone plugging another phone into the line ...
- Home Phone
