How can I disable 1571?
donmaico6
Where there should be a box to tick there is a green box which does nothing when I click it.The problem I have is I recently bought a BT 8610 trio phone set and I cannot get the answer phone to work on it because apparently it does not work well when 1571 is switched on,Could someone please advise me? thanks
2 REPLIES 2
MatthewWheeler
Fixes: 479
Re: How can I disable 1571?
Thanks for getting in touch @donmaico6
I've requested that 1571 be removed from your line and this should go through in the next hour or so.
You'll receive an e-mail confirmation once it's been removed.
Let us know if there's anything else we can help with
 Matthew Wheeler
donmaico6
thanks
