How can I block 0012 102 490 540
- Home Phone
- Re: How can I block 0012 102 490 540
25-06-2014 7:48 PM
The title says it all really - how can I block 0012 102 490 540?
This is a scam and is incredibly annoying due to the frequency of calling. It must be possible to block it somehow.
Message 1 of 5
(1,754 Views)
4 REPLIES 4
25-06-2014 8:22 PM
Personally I'd buy one of the call blockers from Amazon or a call blocking phone from BT.
Actually - I'd design my own unit but that's only because I'm an electronics engineer. My argumentative streak has all but eradicated any current cold calling companies.
Something like this would work nicely :
http://www.amazon.co.uk/CPR-Global-CPR106-All-in-One-Blocker/dp/B004BTVQ5E/ref=sr_1_1?ie=UTF8&qid=14...
Or BT's solution :
http://www.productsandservices.bt.com/products/landline/phones?s_intcid=con_bt7610_nomorenuisance
Or BT's solution :
Message 2 of 5
(545 Views)
25-06-2014 8:24 PM
If it's any consolation, you're not alone with your annoyance :
http://www.whocallsmefrom.com/0012102490540
Message 3 of 5
(545 Views)
25-06-2014 9:08 PM
I have had the same problem with a other "international" numbers but I have been able to block them using the blocking feature on my Panasonic cordless phone.
It also blocks the call to any other phones on the same line even if they don't have the blocking feature.
Hope this helps.
Hope this helps.
Message 4 of 5
(545 Views)
26-06-2014 1:07 PM
You're not alone. I am getting them too.
Message 5 of 5
(545 Views)
- Home Phone
