How can I add Anytime Calls to my existing package?
- Home Phone
- How can I add Anytime Calls to my existing package...
19-02-2015 5:04 AM
Hi, I'm ready to add a £5 pm Anytime Calls package to my existing contract, but can't find any easy way of doing that on-line. There are plenty of references to Anytime Calls there, but apparently no simple way of adding it. Is calling and waiting in the phone queue the only method?
Message 1 of 5
(1,359 Views)
4 REPLIES 4
Re: How can I add Anytime Calls to my existing package?
19-02-2015 9:35 AM
https://portal.plus.net/index_portal.html
Product Change in the top menu bar
Message 2 of 5
(921 Views)
19-02-2015 11:03 AM
Message 3 of 5
(921 Views)
19-02-2015 4:59 PM
Thanks OldJim and thanks Tony. Got it all sorted now, but I found it quite hard to find and add that £5. I was put off on my first attempt by the price of my package being shown on the portal without my discount, and it was that which caused me to go and raise the ticket that Tony has now answered. I suggest there's some scope for making it a bit simpler to add or subtract that £5 Anytime Calls package on-line. I reckon by making it a bit simpler and more obvious, you could save yourselves some tickets and phone calls in future.
Message 4 of 5
(921 Views)
19-02-2015 5:12 PM
Glad to hear you've got it sorted
Really sorry for the confusion involved.
Message 5 of 5
(921 Views)
- Home Phone
