How To Download CSV File Of Calls
scfnet
There used to be a way of downloading a csv file for previous months calls. There was a drop down that let you pick the month.
Now all I can find is the "latest calls" which looks like calls in the current billing period.
Does the facility to download previous calls still exist? If so where?
Alastair
4 REPLIES 4
Marsh
Fixes: 41
Re: How To Download CSV File Of Calls
Hey @scfnet,
I have checked this for you and can confirm that the option to export to CSV is still available. You need to go to Billing and Payments, scroll down to the bottom, and click on Manage Phone Bill. Then, if you click on View Billed or Unbilled Calls, there should be an Export button.
Josh
scfnet
Thanks, not sure why I couldn't see that before but all works now
Alastair
Charles101
Still can only seem to get a CSV for a very limited time. May need for past 6months to year or more for inland revenue for instance.
scfnet
Josh's instructions were almost correct apart from the very last bit
Login to https://www.plus.net/member-centre/billing-payments
Go right to the bottom and select "Manage Phone Bill"
Click "View Billed Calls", clicking "View Unbilled calls" doesn't do the same
This gets you a drop down to select billing periods for the last 15 month.
