Home phone: what do I get?
- Home Phone
- Home phone: what do I get?
17-02-2011 11:08 PM
I am considering switching from BT to Plusnet home phone, and I want to know what I will get:
1) Will I keep my existing BT number?
2) Will I get caller ID display, so I can see the number calling me?
3) Will I get 1471 (last call information)?
4) Will I get call minder (1571 - answer service)
Message 1 of 6
(1,332 Views)
5 REPLIES 5
Re: Home phone: what do I get?
17-02-2011 11:21 PM
See http://www.plus.net/support/phone/home_phone/phone_faq.shtml also look at the call features link at the top of that page.
1. Yes
2. Yes, but at an additional cost
3. Yes
4. Yes (ish) see the features linked above.
1. Yes
3. Yes
Message 2 of 6
(441 Views)
18-02-2011 7:11 AM
the additional cost for me is £0.99 per month
Message 3 of 6
(441 Views)
15-03-2011 10:51 PM
Following on - a couple more questions.
At the moment I am ex directory (heaven!!) - will I stay that way with Plusnet Home Phone?
My number is withheld on all out going calls, I can "un"withhold it by prefixing 1470. will I stay that way with Plusnet Home Phone?
Message 4 of 6
(441 Views)
15-03-2011 11:19 PM
Welcome to the forum
you can be X directory on PN, just make sure you ask for it on a ticket when you apply. not sure about number with held
these are the available features
Caller Display £0.99 per month
See who is calling you with Caller Display (requires a compatible telephone handset)
Call Waiting £2.50 per month
Be alerted if you have an incoming call while you're on another call.
Call Divert £2.50 per month
Direct your incoming calls to any UK landline, mobile, or even most overseas destinations.
Ring Back £2.50 per month
Get a call back if the number you're dialling is engaged.
Reminder Call £2.50 per month
Set your phone for an alarm call.
Anonymous Call £4.00 per month
Bar incoming calls from people who withold their number.
Voicemail £0.00 per month
Message 5 of 6
(441 Views)
16-03-2011 8:26 AM
think carefully before you change its great while alls well but when there is a fault with the phone line it can take some time to get sorted as plus net use BT engineers and in my experience its not good I am now on day 12 without my landline
Message 6 of 6
(441 Views)
