Home phone voicemail
Richard-261
Hello
Is it possible to extend the number of rings before the Home Phone Voicemail answers?
I'm in a wheelchair and nearly never get to the phone before the voicemail cuts in.
Richard
2 strokes good - 4 strokes bad : George Orwell.
6 REPLIES 6
198kHz
Fixes: 41
Re: Home phone voicemail
On standard Voicemail, no - it's fixed at 'medium' (seven rings).
Voicemail Extra (£3 per month) offers the facility to change the timing, thus:
Change how many times the phone rings before Voicemail Extra answers
  1. When you hear the main menu press 2 to go to Personal Options
  2. Then press 3 to go to Calling Options
  3. You'll be shown what the number of rings is currently set to
  4. Press 0 to choose 'immediate' (no rings)
  5. Press 1 to choose 'short' (four rings)
  6. Press 2 to choose 'medium' (seven rings)
  7. Press 3 to choose 'long' (ten rings)
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Richard-261
Thank you.
I wonder if its possible to simply turn the voicemail off...
198kHz
Fixes: 41
@Richard-261 wrote:
...turn the voicemail off...
Yes - it's provided by default, but if you log in to your account, and then click on
https://www.plus.net/plustalk/index.php?page=wlr_add_call_features
you can turn it off.
It has to be said that Plusnet's systems are frequently flaky, so if it doesn't work, post another reply here and one of the Plusnet Help Team will sort it.
MasterOfReality
Fixes: 57
@Richard-261 - 198kHz is correct.
Can you give it a go and let us know if we need to look into this further?
Thanks,
MoR
Richard-261
I certainly will, but it might not be for a day or two. A bit preoccupied.
OskarPapa
Fixes: 65
That's great, @Richard-261.
Please do let us all know how you get on.
If you need anything else in the meantime, please get in touch.
