Home phone not working
pennyb2019
Hi
My phone line seems to be down again. Internet is working fine. I've tried the troubleshooting - connecting to master socket, another handset and unplugging everything. There is no dial tone on the line. I've tried calling the landline from my mobile, but when I pick up the landline I can hear ringing out as if I'm calling someone and the call doesn't connect on my mobile.
Please would you be able to look into this?
8 REPLIES 8
sid28
Re: Home phone not working
I've had the same problem for a week now. I was given a date of the 16th for it to be resolved but still nothing!  No-one has updated me about the problem either.
pennyb2019
Hi
I forgot to add that when I receive a call on the landline. Caller display comes up that someone is calling, but the phone doesn't ring.
Fixes: 160
Try on on-line fault reporter below.
pennyb2019
Thank you.
I've tried the troubleshooting and still no joy. Please can this be raised as a fault?
Fixes: 160
What happened? Sometimes the phone fault checker reports that it has failed ... but has successfully raised a fault report. Use the PN ticket link below to see if a fault report was raised.
pennyb2019
Thanks for your message and help.
Phone line checker says something went wrong and I can't find a fault report has been raised, so have raised a ticket on the website.
adamwalker
Fixes: 221
I've just reported the fault to Openreach for you and have added an update to your account here: https://www.plus.net/wizard/?p=view_question&id=195295596 - Adam
 Adam Walker
pennyb2019
Thank you Adam
