Home phone not ringing
rvw88
Re: Home phone not ringing
Thank you all for your efforts.
It's nice to know that should a problem arise there is help on hand.
Very refreshing after having to deal  with Virgin for years
Fixes: 245
To be clear, so far there have only been other customers responding on this topic.
I’ve requested input from a staff member on the completion of the number port away from Virgin when that service ceases. There is still an opportunity for this to go wrong.
chrisdavison707
Interesting thread as I have EXACTLY the same issue - Virgin to Plusnet migration and no incoming calls.   Did the OP ever get this issue resolved?   If so, an update would be very helpful.
Thanks!
Fixes: 245
Hi Chris,
Welcome to the forums.
This does seem to be a characteristic of migrating away from VM.  Migrating from VM is not like migrating from one CP/ISP to another CP/ISP on the BT Openreach local network.  When you migrate, you start with the new provider and cease with the old provider at one and the same time assuming nothing goes wrong.
When you migrate from VM to a provider on the BT Network, things a a bit different...
  1. The gaining provider dose not terminate the service with VM - you have to do that
  2. When the BT Line is setup, it is allocated your existing VM number
  3. You can dial out on that line and called parties will see the call as coming from your number
  4. HOWEVER inbound calls are routed to the VM line until service with VM is ceased
So until the service is terminated with VM you need to have a handset connected to each line.
rvw88
Hi again all you locked in people.
The saga has gone on with VM for months now.
It turned out that someone in VM decided to sign me up for a new home phone service.
I even had threatening emails telling me to pay my account.😮
After many (ignored) letters to VM I told them I was escalating to the Ombudsman and asked them for a deadlock letter.
That stirred something up in the VM murky pond as I got a letter from them asking me to contact their  AI system by phone text.😲
Yep, you guessed it, a complete waste of waste of time.
Again more letters and more rubbish from them.
Latest letter recived yesterday, dated 4th August from Customer Services Director, Rachel Barrass
This also offering to  set things right.
I won't be holding my breath.
Still, it gave me something to do in the lockdown😂
198kHz
Fixes: 42
@rvw88 That's awful. 😕
Hope the saga has a happy ending eventually - do let us know.
BT technician (Retired)
Fixes: 245
It really does not help that there is no inside-the-industry joined up process for migrating away from VM. It ought not to be possible for the same number to be attached to two different lines.
