Home phone not making or receiving calls
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Home phone not making or receiving calls
04-04-2020 7:46 PM
I have no dial tone on my landline, and the phone doesn't ring when called from a mobile.
On my handsets it says "Check phone line" but there is nothing obviously wrong with the connection.
Can't get through to Plusnet helplines and the chat seems to be down.
any ideas, anyone?
Fixed! Go to the fix.
04-04-2020 8:19 PM
Two suggestions: Check all phone cables are properly seated - you probably have, so apologies if so. Plug a phone (preferably corded) direct into the test socket behind the front plate of your phone socket - with no other items (Sky box, router &c) and see what, if any, change occurs.
Is your broadband OK?
06-04-2020 6:00 PM
@Broom71 Hi there, we couldn't find any faults when running our testing. Please try some of our checks and let us know if it doesn't work after completion: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
06-04-2020 7:25 PM
Thank you, but I acted on the earlier advice and that has fixed my problem, so it was clearly with my connections and not the line.
stay well,
Broom
06-04-2020 7:26 PM
Dear John,
Thanks very much for your reply. I followed your advice and it has fixed my problem -- I guess the connections must have been dirty or dusty.
with best wishes
Broom
06-04-2020 7:29 PM
@Broom71 No problem - as you posted your 'this fixed my problem', I was just typing a suggestion that you did so 😁.
- Home Phone
