Home phone no dial tone
voyager
Good evening
My two home phones, both have no dial tone and do not work, the internet works fine.
Can you help?
Best regards
Andrea
7 REPLIES 7
Fixes: 1,586
Re: Home phone no dial tone
Hi Andrea.
I'm sorry to see you're experiencing problems with your phone service.
Our tests are showing a potential fault on BT equipment at the exchange, so I've reported this through to our suppliers for further investigation and we've been advised an estimated response time of by 29/07/19 17:00:00 for an engineer to go out and investigate further. Let us know how it goes over the next few days.
voyager
Hi Anoush
Thanks for escalating. I'll be in touch if there is any change.
Best regards
Andrea
Fixes: 1,586
Hi Andrea
No problem, I've just checked the fault report before logging out for the night and it's already assigned to an engineer. This likely means it's in an engineer's work-stack for tomorrow as opposed to an engineer out on the job tonight, although that's always possible and not uncommon. Fingers crossed it's fixed soon.
voyager
Hi Anoush
My phone is working!
Thank you and your supplier very much for acting so promptly.
Best regards
Andrea
Mads
Fixes: 79
That's great @voyager.
I've cleared that fault for you, if you do have any further issues please do get back in touch with us.
Thanks.
sid28
Having the same issue. Cordless phones saying line cord error. Have unplugged etc but no joy! Openreach have been in my area so I wonder if it's connected? Please help.
LordFoul
Fixes: 32
Hi @sid28,
Thanks for getting in touch.
Apologies for the issue you're experiencing, I've check the line and it does appear there's a fault somewhere.
I've raised this with our suppliers Openreach. It doesn't appear an appointment to visit your property is required at this stage as the issue is somewhere else, however you can follow the fault progress or add to the ticket here.
If you need any further assistance, please let us know.
Thanks - LF
