Home phone & fibre broadband
- Home Phone
- Home phone & fibre broadband
29-03-2012 2:31 PM
If I converted to fibre broadband my copper wires would go to the green cabinet in the street.
So what would happen to my analogue home phone calls? Would they also come from the green cabinet and would the sound quality improve as a consequence? Or perhaps it would get worse if the path traveled was more complicated.
Peter
Peter
Message 1 of 6
(1,973 Views)
5 REPLIES 5
Re: Home phone & fibre broadband
29-03-2012 4:05 PM
The phone line stays the same (copper from the exchange to your premises), it's just the fibre that is sent down the new connection so there shouldn't be any change to the phone service.
Message 2 of 6
(669 Views)
29-03-2012 4:42 PM
Thanks, Matt.
So that implies that I will end up with two copper pairs coming into my flat, one for the analogue telephone from the exchange and one for the broadband from the green fibre cabinet in the street. How will they route the second pair? The existing pair comes in through the concrete floor of the flat somehow. Will I need extra cabling mounted externally?
Frankly, I had thought that it would all come in through the existing copper pair, as now.
Peter
Peter
Message 3 of 6
(669 Views)
29-03-2012 5:07 PM
Apologies - the fibre service joins the existing copper wires at the cab, so the engineer will just fit a new master socket with a fibre faceplate (and the extension kit and socket, if having the router at the master socket won't work) so there'll be no need to have new wiring fitted. Sorry about the confusion there.
Message 4 of 6
(669 Views)
30-03-2012 1:41 PM
Thanks, Matt.
It's a pity it works like that. I was really hoping that the home phone voice calls would come down the fibre to the cabinet with the broadband, so that I might get some improvement in the quality of voice calls. But from what you say the route of my home phone voice calls will have to be extended via the cabinet and this may result in a further degradation of my already low quality analogue voice calls. I think I'll avoid fibre for that reason.
Peter
Peter
Message 5 of 6
(669 Views)
30-03-2012 5:15 PM
I'm not sure what you mean?
On ADSL, the phone and broadband services are joined and sent down the same twisted copper pair to your local cabinet and from there to your premises.
With fibre, the phone travels exactly as it always has - down the copper pair from the exchange, to the cab, and then to your premises. However instead of the broadband joining the line at the exchange, it joins it at the cabinet.
There'll be no change at all to your phone line quality if you do go for fibre
Message 6 of 6
(669 Views)
- Home Phone
