Home Phone anytime
- Home Phone
- Home Phone anytime
Home Phone anytime
12-12-2007 11:28 AM
If I add home phone to my broadband,will I be able to use at the same time or will my home phone ring engaged for the period I'm using my broadband ?
Message 1 of 3
(1,722 Views)
2 REPLIES 2
Re: Home Phone anytime
12-12-2007 11:30 AM
Hi Barney,
You'll be able to use them both
Because Broadband runs on a different signal to your normal analogue phonecalls, you can use them both at the same time.
Message 2 of 3
(457 Views)
12-12-2007 11:53 AM
Thanks for your prompt reply, i'll go & order it now.
Message 3 of 3
(457 Views)
