Home Phone Paying Via Debit Card not DD
- Home Phone
- Home Phone Paying Via Debit Card not DD
03-04-2009 6:35 AM
Mark
Re: Home Phone Paying Via Debit Card not DD
03-04-2009 8:13 AM
Phil
03-04-2009 9:04 AM
03-04-2009 9:12 AM
Also its do to with the credit limit that is setup which varies on which produce you take out.
03-04-2009 11:55 AM
03-04-2009 12:25 PM
Whilst DD gives the security of being able to easily cancel (much more difficult to stop a CA on a CC), if you are dealing with a reputable company it shouldn't make any difference.
As regards claiming back on a DD when a mistake is made, I'm not so sure I would want to do that (except as a last resort) because of the way PN seem to treat such as failed billing, and then you'd get your phone stopped, BB stopped etc. So in practice, I don't see any real difference.
I don't think 'credit limits' are even a significant factor with the maximum typically achievable likely monthly PN bill, so I don't think my carrots or broccoli have any bearing on it
03-04-2009 12:30 PM
03-04-2009 12:35 PM
03-04-2009 12:39 PM
03-04-2009 12:46 PM
[CC payment give them greater security as payments get process far quicker (usually hours) ].
03-04-2009 12:56 PM
03-04-2009 1:02 PM
03-04-2009 1:55 PM
03-04-2009 8:46 PM
03-04-2009 8:55 PM
(PS. Well done for the sig line change
- Home Phone
