Home Phone Control Panel not showing all calls
FIXED- Subscribe to RSS Feed
- Home Phone
- Home Phone Control Panel not showing all calls
08-02-2017 5:37 PM
My Home Phone Control Panel isn't showing my phone calls. For the period 7th Jan to 6th Feb, it only lists two calls.
Can this be fixed?
Fixed! Go to the fix.
Re: Home Phone Control Panel not showing all calls
08-02-2017 5:46 PM
Good afternoon, looking at things our side I can see 2 calls were made since yesterday(7th), but when checking for the dates you've given this shows the normal amount of calls I'd expect given your phone usage over the past few months.
08-02-2017 5:50 PM
I don't think that's correct! For the period I mentioned, there are just two calls I can see, both dated 4th Feb and absolutely nothing during January (from 7th)... which isn't typical.
08-02-2017 5:57 PM
Thanks for getting back to me so quick.
I've checked further and can see the 2 calls you mention, both dated the 4th but listed on the control panel under the current month due to the way calls are processed, if you set the drop down menu next to "view bill:" on the itemised bill screen to 07/01/2017 to 06/02/2017 and click "GO" this should bring up the last month which is showing what I would call a normal amount of calls.
If this doesn't work could you try using another browser and letting me know if there are any issues
08-02-2017 6:02 PM
You're a super-star - thank you very much!
In my defence though... is the "Go" button new? I've an idea the page used to auto-refresh when selecting a different date range in the past! Regardless, thanks again!
08-02-2017 6:05 PM
I'm not entirely sure it's new but it threw me off at first so it may possibly be.
It's been a little while since I actively worked on customer accounts so a few changes have slipped by me
Let me know if you have any more issues
08-02-2017 8:31 PM
Not entirely sure why it was changed though, but apologies.
- Home Phone
