Home Phone Call Blocker
- Home Phone
- Home Phone Call Blocker
10-06-2018 12:21 PM
Talk Talk have introduced an amazing Call Blocker called CallSafe. It blocks all nuisance calls and is free. I would like to know when Plusnet are going to offer a similar service. Until hearing about this (my sister has it) I used to recommend Plusnet, but will no longer do so until this feature is available.
Re: Home Phone Call Blocker
10-06-2018 12:24 PM - edited 10-06-2018 12:27 PM
Try Plusnet's Call Protect.
10-06-2018 2:19 PM
Or alternatively keep control yourself by buying a telephone that includes a BT Call Blocker such as https://www.amazon.co.uk/BT-Advanced-Cordless-Nuisance-Answering-Black/dp/B0787H2X6Q/ref=dp_ob_title...
I've had an older model for several years now and over that time had no nuisance calls whatsoever.
10-06-2018 4:38 PM
Sadly that has already been hacked. I’ve had calls from 0123456789012.
You don’t exactly need a Maths degree to realise that is a fake number,
10-06-2018 5:21 PM - edited 10-06-2018 5:22 PM
Hi @Steambuff48,
Thanks for getting in touch and welcome to the forums. We do have a call feature called Plusnet call protect that is completely free to help with these pesky calls. You can find out more information on this here, and add this through the Member Centre.
Please let us know if you need any further assistance.
10-06-2018 6:51 PM
@Alex wrote:
I assume they just use CLID and block certain numbers.
The BT system is different. If the caller is not in your permitted list then the unit answers the call and asks the caller to identify themselves followed by the hash key. It is only after the hash key has been pressed that the phone rings. You are then told who is calling and given four options, answer the call this time, answer and put the caller in the permitted list, transfer the call to the answering machine or permanently block the number. If the hash key is not pressed after the caller is asked a few times the call is dropped and apart from the number appearing in the callers list you have no idea they rang. This thwarts the automatic diallers that the baddies use to the extent that I have never had to add a number to the blocked list.
10-06-2018 8:01 PM
As far as I can see, Plusnet's version works by setting up calls you want to block. Talk Talk works on the basis that you set up only the numbers of people you know. If anyone else rings then the system asks them to record their name. Most annoyance callers give up at this point. If the caller speaks their name then your phone rings, plays the short recording, and asks if you want to accept. You can accept, reject or block at this point. It offers an almost identical approach to that offered by the BT Advanced Phone except you don't need to buy a special phone.
10-06-2018 8:04 PM
Well in fact I have one of the BT Advanced phones. It was my sister who was offered the alternative from Talk Talk which doesn't involve buying a new phone
10-06-2018 8:05 PM
They don't use anything to block numbers. You set up your own personal list of numbers of people you know. If anyone else calls then the system asks them to record their name. Most annoyance callers give up at this point. If the caller records their name, then your phone rings and plays the short message. At this point you can accept the call, reject it or block it. The caller from your fake number almost certainly wouldn't have recorded their name to try to get through.
10-06-2018 8:08 PM
I think the BT system to which you refer is the 'BT Advanced Phone' - which is what I currently have. The approach offered by Talk Talk is almost identical except that your call list is set up via a web page and you don't need to buy a new phone.
10-06-2018 8:31 PM
I sometimes have to tell them to go away. I feel like doing a far more sweary version of that remark, but the way things are going here of late, I won’t..😬
10-06-2018 11:12 PM
Hi Alex,
Both the BT Advanced Phone and the Talk Talk CallSafe would resolve your problem with callers withholding their call ID. Both systems would ask the caller to record their name before you receive the call. In my own experience I have had only a single case of such a caller going this far since November 1986 when I installed the BT phone - and of course I didn't accept it!
Cheers
