Help - on phone incoming or outgoing
richfw12
No dial tone or in/out calls. It's been broken a few days now.
8 REPLIES 8
Fixes: 334
Re: Help - on phone incoming or outgoing
@richfw12 Welcome to the forums. I suggest you follow this link https://www.plus.net/help/report-a-problem/phone/ , but as it is late in the day, don't be surprised if you don't get a response until tomorrow (or possibly Monday).
TheMightyAJ
Fixes: 126
Hi @richfw12,
I'm sorry to hear that you're experiencing issues with your landline. I've tested the line this afternoon and we haven't been able to locate any underlying faults, so I'd ask if the issue is still present on your end of things and if so, have you been able to carry out any sort of troubleshooting steps at this stage? For reference, we have a guide on home phone faults, here.
 Alex H
richfw12
Thanks will check further on the guide. Given the broadband is working, I suspect it may be the phone base station then.
RealAleMadrid
Fixes: 66
@richfw12  I wouldn't make the assumption that your phone or base station is faulty, if you are on FTTC which Plusnet call Fibre it is quite possible for the broadband to work normally and the phone to not work at all. If there is a line fault between the exchange and the local Phone cabinet it will not affect the broadband. Easiest test is to get hold of another known working phone and try it.
richfw12
Agreed - trying to track on down.
richfw12
Without any other checks, since the line checks, our phone has started working again. Curious, but at least working now.
Fixes: 1,639
Thanks for getting back to us @richfw12
I'm glad to see your phone's working again, albeit by itself.
Let us know if you have any further issues and we'll be happy to help.
Fixes: 236
A note of caution - some bad joint issues can be “fixed” by the act of line testing or ring current being applied to the line. Keep a watch on the line.
If one side of the circuit is iffy you can lose voice services whilst broadband still limps along. Dial 17070 check the phone number is correct, select option 2 check the line is totally silent.
