Help on external (BT wiring) to property
- Home Phone
- Help on external (BT wiring) to property
- « Previous
- Next »
Re: Help on external (BT wiring) to property
13-07-2010 1:01 PM
External wiring damage caused by the weather, trees, Acts of God, etc. etc. are not chargeable. Deliberate damage, however, is!
Message 31 of 35
(1,336 Views)
13-07-2010 2:44 PM
Quote from: BenTrimble External wiring damage caused by the weather, trees, Acts of God,
Pray for a very strong wind to blow a tree down and pull the cable off the fascia - a winner on 3 counts then
Message 32 of 35
(1,336 Views)
02-08-2010 12:16 PM
Update - I have just talked to the fitter who is installing a uPVC window and fascia (not the part with the wire attached) and he advised that they would have no problem with removing the connection to the wooden fascia and re-attaching it after replacing it with plastic without involving BT
Message 33 of 35
(1,336 Views)
02-08-2010 3:55 PM
Just don't mention the fascia change if it develops a fault when it's been put back.
Message 34 of 35
(1,336 Views)
20-09-2010 5:38 PM
All done with no problems
Message 35 of 35
(1,336 Views)
- « Previous
- Next »
- Home Phone
