Help !!! How Do I Reduce My Credit Limit?
- Home Phone
- Re: Help !!! How Do I Reduce My Credit Limit?
02-07-2010 12:05 AM
I urgently need help on this issue.....I need to control my outgoing calls because of my children, fine they can use the broadband i don't really care about that, but I need a way to control my outgoing call. Or reduce my credit limit..
Bt offers calls control method. Other phone company offers calls control solutions.
I need to be in charge of my outgoing call
jim:orange All caps changed as per forum rules
02-07-2010 8:33 AM
I appreciate your quandary.
You can reduce the credit limit by raising a ticket to request it - I did.
However that probably won't solve your problem as when you reach it all outgoing calls will be barred and there will be a charge added to your next bill http://www.plus.net/support/phone/home_phone/billing.shtml#howCredit
Would it be correct to assume that your problem is calls to mobiles. I don't know if there is a facility for blocking outgoing calls to a range of numbers but hopefully a Digital Care Team member will be along to advise
Quote 13. What if I use my credit before the end of the month?
If you reach your credit limit, all calls (apart from emergency 999/112 and operator) will be barred and a charge of £5.76 will be added to your next bill.
Before this happens, we'll email you as you reach £15, £10 and £5 available credit.
You'll need to top-up and have at least £5 credit available before we allow calls on your line again.
You can prevent this by topping up your credit through the month using the Home Phone Control Panel.
You can top-up by £5, £10, £25, £50, £75 or £100.
02-07-2010 10:27 AM
I'll add a ticket to your account for you with details, if you return that to us letting us know what would be best we'll get it sorted for you.
Hope that helps,
02-07-2010 11:14 AM
http://cgi.ebay.co.uk/COMMTEL-PHONE-GUARD-CONTROL-YOUR-HOME-OFFICE-PHONE-BILL-/390189015714?cmd=View...
09-07-2010 12:50 PM
09-07-2010 12:53 PM
Cancellation 0845 140 6002 09:00 – 17.30 every weekday (except Bank Holidays)
Be careful - are you talking about cancelling your account or moving to another supplier.
Cancelling will land you with cancellation charges.
If you want to move your broadband to another supplier then you should ask for a MAC code.
If you want to move your phone to another supplier you should contact the new supplier and they will arrange it.
09-07-2010 1:11 PM
09-07-2010 1:12 PM
09-07-2010 1:22 PM
thanks
09-07-2010 1:24 PM
09-07-2010 1:26 PM
If this is the case and Plusnet can't offer it transfer your phone line to BT and enable Call Barring for a cost of £2.59 per month
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=25504 and click on Home Phone Security Features
If you want to cancel everything have a look here as this should tell you https://portal.plus.net/my.html?s=0&action=account_summary
09-07-2010 1:36 PM
i hope d transfer can be made
@ no extra cost for transferring my service to BT
09-07-2010 1:46 PM
I don't believe there is a charge as you probably paid for the initial phone line installation up front
09-07-2010 2:11 PM
Have you restricted the cost of your broadband https://portal.plus.net/data_transfer_watch/
09-07-2010 2:15 PM
Thanks for your time on the phone - as discussed the order for outbound call barring has been placed and should complete for you later on this afternoon.
I hope that helps, and sorry for all the hassle.
- Home Phone
