Help Cannot make phone calls - do have fibre working though!
- Home Phone
- Help Cannot make phone calls - do have fibre worki...
08-03-2014 2:07 PM
We can receive calls though.
Is there a problem in my {Milton Keynes] area?
Once again - HELPPPPP!
Mike
Re: Help Cannot make phone calls - do have fibre working though!
08-03-2014 2:10 PM
https://portal.plus.net/wizard/?p=wizard&page=22945&wizard_id=38
08-03-2014 2:26 PM
08-03-2014 2:36 PM
Online fault finding says plug in old style phone to see if we have a dial tone.
{Sadly, me and my 9 neighbours only have DECT phones.......}
Annoyingly the next piece of help advice [if you say you have done that and still have no dialling tone] is to RING one of two numbers.....
I used the link above and filled it in.
Apparently tickets are taking over 34 hours - maybe longer.......
09-03-2014 11:06 AM
Plugged it in AND................................... NO difference.
Plugged it into the master socket - NO difference.
I am partly disabled and holding onto a mobile for ages waiting for support is more than hard.
HELP PLEASE!
09-03-2014 11:07 AM
10-03-2014 12:00 AM
HOWEVER I HAVE NOW BEEN ABLE TO REACH SUPPORT.
There IS a line problem.
It should be fixed within 4 days.......
10-03-2014 9:40 AM
Sorry to hear of the issues regarding your phone service.
I can see that this is in hand with our Faults team on Ticket: 82552111 and the estimated repair time is 12/03/14 23:59:59.
Our Faults team will continue to monitor this for you.
22-03-2014 2:05 PM
Tried swopping phones - no good. Reported to BT .... told to deal directly with PN ! But BT own PN and also supply the line !?.
(Previous correspondence above suggests that the less contact with BT the better).
Alas PN had its usual 30 min waiting queue. Reluctant to spend 30mins on my basic Tesco mobile as worried about calls cost.
Q1. are the PN 0800 calls free from mobiles ... us 84yr-oldpensioners worry about costs.
So gave up for the day and lo! all was well next morning.
Q2. Is this 'phone-line down' a common occurrence with PN ?
22-03-2014 2:07 PM
Q2 No more common than with any other provider as the phone connection doesn't go anywhere near any Plusnet kit
22-03-2014 2:50 PM
My message should alert you to my need for advice as to how to deal with the issue of cost when using a basic mobile phone and faced with 30+mins waiting time when my PN landline is down.
I looked up your GiffGaff on Google and it is a monthly installment service which would not be for me using the mobile only for emergencies.
Should I expect a 30-min wait on a non-free number to get attention from PN when landline is down?
22-03-2014 3:00 PM
I realise it doesn't help you this time but it is something for the future
Quote Free to giffgaff
You need to top-up by top-up voucher, top-up by credit /debit card or buy a goodybag from your credit /debit card at least every 3 months to receive free giffgaff to giffgaff calls. If you don't, other UK rates will apply as above. The free giffgaff to giffgaff calls last for 60 minutes per call, so you need to hang up and re-dial if you want to keep talking for free.
However http://www.theguardian.com/media/2013/dec/12/ofcom-free-0800-mobile-telecoms-overhaul
Quote The telecoms watchdog said that from June 2015, "freephone will mean free" for 0800, 0808 and 116 numbers – which at present are free only when used in a landline, and which cost mobile phone users between 14p and 40p a minute.
22-03-2014 4:59 PM
Residential call stats
Current calls waiting Longest call waiting now Average answer time today
1.66 2 minutes and 20 seconds 44 seconds
Last updated: March 22, 2014, 4:50 pm
22-03-2014 7:43 PM
I am also surprised but more by the fact the 1.66 calls are waiting 🙂
23-03-2014 8:28 AM
- Home Phone
