Has anyone ported a (PlusNet) landline to a virtual provider?
herman01
I'm moving to a new area for 6 months and I want to keep my phone number (which I have had over 25 years)
PlusNet can't reserve it for me and because my new house is on a different exchange they can't transfer.
Their only option is to keep both broadbands going.
Has anyone been able to transfer a PlusNet number to a virtual phone provider?
1 REPLY 1
Fixes: 383
Re: Has anyone ported a (PlusNet) landline to a virtual provider?
I've ported a PN number to VOIP with no problems. AFAIK Virtual landlines are basically voip, usually supplied with a forwarding facility to another number.
Porting your existing number will automatically cease the landline and any associated broadband, so if you are still in contract then ETC's will apply.
