Handset facilities not working
- Home Phone
- Handset facilities not working
21-07-2014 12:31 PM
Just joined Plusnet for phone and broadband and after connecting my cordless phones I have noticed that the missed calls, caller ID and answer-phone facilities are not working. These are handset based not provider based - i.e. caller ID comes from the memorised phone-book saved to the handset.
The Openreach engineer that connected the broadband reckons its something BT needs to sort out but I pay Plusnet for line rental.
Re: Handset facilities not working
21-07-2014 12:34 PM
Caller ID needs to be enabled on your line for you phone to be able to convert the number to a name from the phonebook. PN charge an extra 99p/month for this to be turned on.
21-07-2014 12:45 PM
The particular BT Synergy handset was specifically bought because it has all three built in.
21-07-2014 12:57 PM
Quote from: Mossback
If you check the box and/or user manual it'll probably confirm what pwatson has told you
21-07-2014 1:12 PM
You can check if this is the case by looking at your call features here: https://portal.plus.net/plustalk/index.php?page=wlr_my_account
21-07-2014 1:42 PM
Maybe TalkTalk gave caller I.D. for free, and I do have 1571 in my package that might be kicking in before the TAM has had a chance. Could 'missed calls notification' be part of caller I.D. ?
I will try and find the handbook for the phone, there is one somewhere amongst the moving paraphernalia yet to be unpacked.
21-07-2014 1:47 PM
Phil
21-07-2014 1:50 PM
Quote from: Mossback Could 'missed calls notification' be part of caller I.D. ?
Yes - If Caller ID isn't on your line the phone doesn't know the number of the caller, answered or not.
21-07-2014 1:57 PM
Thanks to all that have replied.
- Home Phone
