Go back to a previous BT landline number
ijandkj
Hi
I have just ordered Plusnet Broadband and home phone.
I was with TalkTalk, but before that Sky.  I believe with Sky that I would have been on a BT Wholesale landline number, which I lost when I went to TalkTalk
Would I be able to get that old number back with PlusNet?
3 REPLIES 3
MattyC
Fixes: 46
Re: Go back to a previous BT landline number
Hi ijandkj,
I couldn't answer this one straight away. If you don't mind, please can you PM me the number so I can investigate?
Thanks,
Matty
RobPN
Fixes: 13
Quote from: ijandkj
Have you tried calling your old number?
If someone answers the call then that would confirm  the number is in use as it will have been reallocated, in which case the answer to your question would be a definite no.
MattyC
Fixes: 46
I probably should have updated the thread on this one.
I spoke with OP and the number provided is a spare, so theoretically it's available. We agreed to wait until he's provisioned, and we can renumber the line.
Matty
