Get rid of 1571 - HOW?
harrym1byt
After over two months on Plusnet, I have just discovered that the 1571 BT service seems to have been enabled on our line. I only found out today, because someone said they had left a message and there wasn't a message on our home system, so I guessed at 1571 having taken it.
Anyway, the point is can it be removed/disabled please, we have our own system.
3 REPLIES 3
Anoush
Aspiring Hero
Fixes: 139
Re: Get rid of 1571 - HOW?
Hello @harrym1byt
You should be able to remove the voicemail feature from your account here.
I hope this helps.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Gel
Aspiring Champion
Fixes: 28
Anoush
Aspiring Hero
Fixes: 139
If you haven't done already, you can use the Report to Moderator link under Post Options if you feel a post should be moved to another board. Wink
I've just done that now for this thread.
