Get rid of 1571 - HOW?
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Get rid of 1571 - HOW?
23-01-2017 7:52 PM
After over two months on Plusnet, I have just discovered that the 1571 BT service seems to have been enabled on our line. I only found out today, because someone said they had left a message and there wasn't a message on our home system, so I guessed at 1571 having taken it.
Anyway, the point is can it be removed/disabled please, we have our own system.
Fixed! Go to the fix.
23-01-2017 7:58 PM
Hello @harrym1byt
You should be able to remove the voicemail feature from your account here.
I hope this helps.
23-01-2017 8:27 PM
23-01-2017 8:30 PM
If you haven't done already, you can use the Report to Moderator link under Post Options if you feel a post should be moved to another board.
I've just done that now for this thread.
