Fed up
- Home Phone
- Re: Noisy line again
Fed up
12-01-2015 6:37 PM
I hope this gets sorted quickly and I do not after spend another year back and forth trying to get this sorted again.
My phone and hub have spent more time connected to the test socket than to the extensions.
Re: Fed up
12-01-2015 7:02 PM
Upstream noise doubled - http://community.plus.net/forum/index.php/topic,134873.msg1182021.html#msg1182021
Success after 18 months - http://community.plus.net/forum/index.php/topic,133795.msg1169676.html#msg1169676 (clearly short lived!)
A Record (10 day continuous connection) - http://community.plus.net/forum/index.php/topic,129952.msg1131792.html#msg1131792
Noise on line - http://community.plus.net/forum/index.php/topic,127151.msg1111816.html#msg1111816
Confused - http://community.plus.net/forum/index.php/topic,126497.msg1099239.html#msg1099239
These issues have been on and off for around 12 months...
Re: Fed up
13-01-2015 9:15 AM
I am just looking at your account now and can see the fault ticket as well as the complaint so I will pick that up myself and respond on there.
Kind regards
Sharon
Re: Fed up
13-01-2015 9:26 AM
I have just tried to call both the numbers we have for you and have left a voicemail on your mobile, I look forward to speaking to you soon.
Warm regards
Sharon
Re: Fed up
13-01-2015 6:04 PM
Re: Fed up
14-01-2015 9:07 AM
Warm regards
Sharon
Noisy line again
04-04-2015 8:19 PM
04-04-2015 9:21 PM
Fragmenting your issue over several threads does not help PlusNet see the longevity and repeated failure of fixing your issue.
I joined up your long history in your Jan 2015 punt at this problem which did not appear to conclude albeit in the personal hands of SAB.
I will ask that the mods merge this thread with that thread - http://community.plus.net/forum/index.php/topic,135758.msg1190048.html#msg1190048
In the meantime, I suggest that you use the new phone faults trouble shooter (link below) now - do not wait until Tuesday.
Re: Fed up
04-04-2015 9:31 PM
Threads merged to enable continuity.
Re: Fed up
04-04-2015 9:48 PM
Not easy using online fault diagnosis as my BB keeps dropping but by now I know the score by now.
I like to phone as then the operator gets first hand experience of my problem.
Thanks again. Start and Townman
Re: Fed up
05-04-2015 10:35 AM
You can do the fault report / test from any connection you can get - mobile or a library!
Re: Fed up
06-04-2015 6:15 PM
I've run a quick line test but not been able to find a fault. When you call us, we'll go through a few tests, and once done, arrange an engineer for you.
Re: Fed up
09-04-2015 7:18 PM
Re: Fed up
10-04-2015 4:43 PM
Re: Fed up
11-04-2015 11:59 AM
Updated stats would be useful please.
