Fed up
HaresEar
Fed up
After finally and after many fault reports I got a quiet line.  However for some reason my phone line was disconnected both in the exchange and cabinet.  I even ended up with a sky phone number(the line was quiet) Reconnected today (6 days Off)  and once again I have a noisy phone line.
I hope this gets sorted quickly and I do not after spend another year back and forth trying to get this sorted again. Cry Cry Cry
My phone and hub have spent more time connected to the test socket than to the extensions. Sad Sad Sad
17 REPLIES 17
Fixes: 159
Re: Fed up
This user has had multiple issues / threads over recent months regarding connectivity issues - would it be wise to merge them for easier support?
Upstream noise doubled - http://community.plus.net/forum/index.php/topic,134873.msg1182021.html#msg1182021
Success after 18 months - http://community.plus.net/forum/index.php/topic,133795.msg1169676.html#msg1169676 (clearly short lived!)  Shocked
A Record (10 day continuous connection) - http://community.plus.net/forum/index.php/topic,129952.msg1131792.html#msg1131792
Noise on line - http://community.plus.net/forum/index.php/topic,127151.msg1111816.html#msg1111816
Confused - http://community.plus.net/forum/index.php/topic,126497.msg1099239.html#msg1099239
These issues have been on and off for around 12 months...  Shocked
SharonBrown
Re: Fed up
Good morning HaresEar,
I am just looking at your account now and can see the fault ticket as well as the complaint so I will pick that up myself and respond on there.
Kind regards
Sharon
SharonBrown
Re: Fed up
Hi again.
I have just tried to call both the numbers we have for you and have left a voicemail on your mobile, I look forward to speaking to you soon.
Warm regards
Sharon
HaresEar
Re: Fed up
Thank you for taking charge of this issue Sharon. I look forward to a clear line a high speed stable broadband. Smiley Smiley Smiley
SharonBrown
Re: Fed up
No worries at all Smiley  I will be confirming the fault appointment today and be in touch a little later as agreed to confirm who'll be looking after you while I am out of the office for the next couple of days.
Warm regards
Sharon
HaresEar
Noisy line again
I am now getting seriously fed up with my line always going noisy/faulty. Yes you guessed it strong winds and my line is again naff. I will be reporting this first thing on Tuesday.
Fixes: 159
Re: Noisy line again
Hi HaresEar,
Fragmenting your issue over several threads does not help PlusNet see the longevity and repeated failure of fixing your issue.
I joined up your long history in your Jan 2015 punt at this problem which did not appear to conclude albeit in the personal hands of SAB.
I will ask that the mods merge this thread with that thread - http://community.plus.net/forum/index.php/topic,135758.msg1190048.html#msg1190048
In the meantime, I suggest that you use the new phone faults trouble shooter (link below) now - do not wait until Tuesday.
Strat
Fixes: 565
Re: Fed up
Mod Note
Threads merged to enable continuity.
HaresEar
Re: Fed up
Thanks for merging the thread. I will keep this in mind if there is a next time eek.
Not easy using online fault diagnosis as my BB keeps dropping but by now I know the score by now.
I like to phone as then the operator gets first hand experience of my problem.
Thanks again. Start and Townman
Fixes: 159
Re: Fed up
HaresEar,
You can do the fault report / test from any connection you can get - mobile or a library!
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fed up
I'm sorry to see the problems that you are experiencing.
I've run a quick line test but not been able to find a fault. When you call us, we'll go through a few tests, and once done, arrange an engineer for you.
 Tony T
HaresEar
Re: Fed up
Ok yet another e-side change to fix the fault. How long will this last. mmmmmmmmm
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fed up
One would hope that it is a permanent fix. When we get the "Pair Changed from MDF-PCP" it generally is. We ask that you monitor though, and let us know if you do have other issues.
 Tony T
Fixes: 159
Re: Fed up
HaresEar,
Updated stats would be useful please.
